L'appareil se présente comme un petit dongle USB-C. Il permet de s'affranchir des limites de résolution qu'impose notamment l'iPhone pour la transmission audio en Bluetooth vers un casque, des écouteurs ou des enceintes sans fil.
Le FiiO BT11 sera en vente à partir du 8 octobre à 49 €/42 £/44 $.
Ci-dessous, la présentation (en anglais), les images et spécifications fournies par les services de la marque :
September 25, 2024
FiiO gives iPhone users HD Bluetooth for £42/$44, unlocking 24-Bit, 96kHz wireless audio and finally gives iPhone users Android quality wireless audio...
The new BT11 Portable Bluetooth Transmitter from FiiO easily allows devices such as the iPhone 15 and 16, PS5, and Nintendo Switch, PC and Mac to support high-res Bluetooth transmission.
The BT11 supports a wide range of codecs, including aptX Lossless, LDAC, aptX Adaptive, aptX HD, and more — allowing users to enjoy up to 24-Bit 96kHz wireless audio as offered by the major streaming services.
Available in black and silver finishes, this small device simply plugs into the your iPhone's USB Type-C port and enables high-quality connectivity to wireless headphones and speakers.
The BT11 supports simultaneously connecting to two receiving devices. Equipped with Qualcomm’s flagship Bluetooth chip — the QCC5181 — it features a quad-core processor architecture and two 240MHz Qualcomm Kalimba audio DSPs. The BT11 also supports Snapdragon Sound, which delivers an immersive lossless audio experience with compatible devices.
Thanks to its support for the latest Bluetooth 5.4 version, the BT11 provides a more stable connection, longer transmission ranges, and overall system performance improvements — all at lower power consumption.
Connect the BT11 to the FiiO Control App for iOS and Android and easily control the device and access functions such as simultaneous pairing to two devices. The BT11 will also be upgraded via over-the-air (OTA) updates, with scheduled updates including: addition of the LC3 Codec, volume adjustment, indicator light control, channel balance adjustment, and pairing lists.
The colour RGB indicator light on the BT11 clearly displays the working status of the device, as well as the current Bluetooth codec being used:
SBC Blue pulsing light aptX/aptX Low Latency Purple pulsing light aptX HD Yellow pulsing light LDAC White pulsing light aptX Adaptive/aptX Lossless Green pulsing light Pairing Blue flashing light Waiting to reconnect Red and blue lights flashing The FiiO BT11 will be available from Oct 8th, priced £42 / $44 / €49.
BT11 SPECIFICATION:
Bluetooth Version 5.4 Bluetooth Chipset Qualcomm QCC5181 Bluetooth Codec Support SBC
aptX
aptX Low Latency
aptX HD
aptX Adaptive
aptX Lossless
LDACDimensions 28mm x 21mm x 9mm Weight 3g In the box 1 x BT11
1 x USB Type-A to USB Type-C Adaptor
1 x Quick Start Guide
1 x Warranty CardAvailable Finishes Black
Silver
